Had quite a bit of difficulty registering but it has now let me in!
I have two 800s. One will be known here as "The Green Machine" which is just about to emerge from a respray. The other is a 1997 saloon known as "Thunderbird 2" (saw it on the numberplate when washing it).
Green Machine has had a new windscreen, engine mount and clutch master (was a pig to bleed to get to work...), a fresh MOT and is just being resprayed. LPG is very good. Don't notice it.
TB2 has just failed MOT on CV boot and "emissions". I have been advised that it is the cat. Now all was running well until I had to do a few bump starts due to alternator issues (wasn't charging but had no warning light) but I'll try that first. It's had a low rumble from the belts since I bought it so will be getting a cambelt kit and water pump. It has just had an alternator. Is there a link on the site here to find part numbers as I have had a bit of difficulty getting the right bits? Power steering pump for non AC T16 for one.
Anyway Hello, and I hope to remain an 800 owner for some time.
Hello at Last!
Hello at Last!
Re: Hello at Last!
Hi and welcome to the true fountain of knowledge on the R800!
Re: Hello at Last!
Welcome Scotty2
Re: Hello at Last!
Welcome aboard Scotty! One of the L-series engines PAS pumps fits the T-series :
viewtopic.php?f=9&t=14592
As for the green beastie, you've got a very good car there! You've fixed the major "problem" it had in as much as it was "cosmetically challenged", other than that a great car!
- Joined: Sun Oct 15, 2017 4:29 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Hello at Last!
As other have said, welcome aboard! Glad the green beastie is doing well, I look forward to post-respary photo's. I do miss it now and then but had to sell at the time unfortunately.
Re: Hello at Last!
Welkome! Hope you Will be An 800 owner for long time too. Nice cars.
Re: Hello at Last!
Thanks Marc.
I have two green 800s and looking for a Coupe as a third!
Blimey - Nearly a year between posts!
