| View previous topic :: View next topic |
| Author |
Message |
neo Regular Visitor
Joined: 01 Sep 2008 Posts: 425 Location: caddington beds
1999 Rover 800 Sterling
Posted: Sun Feb 07, 2010 5:01 pm Post subject: one for mr hubbard |
Hi Simon
down the road from the red mk1 i put on there sits a blue tr7 some pics when i get chance ill do some close ups
| Back to top |
CHR15E Site Admin
Joined: 30 Aug 2008 Posts: 7729 Location: Notts. J28 M1
1990 Rover 827 Sterling
Posted: Sun Feb 07, 2010 6:31 pm Post subject: |
Front plate seems to be spaced for some reason?
Does it say something I'm not seeing? _________________ Chris
91 827 Si Manual + matching trailer
90 827 Sterling Project
94 Espace 2.1 DT
94 Espace 2.1 DT Spares car |
| Back to top |
Simon Hubbard Rover Addict
Joined: 01 Sep 2008 Posts: 1013 Location: Sutton Coldfield, West Midlands
1997 Rover Coupe
Posted: Mon Feb 08, 2010 9:41 am Post subject: |
Hi Tony
Thanks for that, i cant quite tell but i think it might be the same colour as mine.
It is nice to see the back end of the car has been left black rather than colour coded. I am fairly confident that this is a Speke built car, i wonder if it is a four or five speed.
I thought the same as you Chris about the front number plate. _________________ Regards
1997 Rover 800 Vitesse Coupe
1996 Rover 800 Vitesse Saloon
1977 Triumph TR7 FHC
1969 Triumph Vitesse mk2 convertible |
| Back to top |
CHR15E Site Admin
Posted: Mon Feb 08, 2010 3:10 pm Post subject: |
| Simon Hubbard wrote: | | I thought the same as you Chris about the front number plate. |
Doesn't look like the rear is the same which is odd. _________________ Chris
94 Espace 2.1 DT
| Back to top |
The Professor Rover Guru
Posted: Mon Feb 08, 2010 7:34 pm Post subject: |
As far as i know i would say it looks like Tahiti blue and that would be correct for that year. I don’t believe pageant blue was introduced until much later approx 78.It definitely isn’t pageant blue. I’m certain its Tahiti.
You don’t see that many of that age. I like them and always have.
Always remember Purdy in the Avengers had one a P reg so it was an early car.
There was also one used in a TV programme called The Wilde Alliance staring Julia Foster and John Stride.
Early episodes of the Professional also had one _________________ Glyn
| Back to top |
Very Tall Brad Rover Addict
Joined: 31 Aug 2008 Posts: 2338 Location: near to Evesham, Worcs
Posted: Mon Feb 08, 2010 7:59 pm Post subject: |
I think mit's Pageant. I had a Tahiti TR7 in 1978 and kept it til about 1981. That was a 4 speed with the blck Bri Nylon seats, black rear panel, black hub caps. PDH 251R, by the way, from Hewitts of Walsall.
The silver, more shaped hubcaps, like on the car pictured, were only on the later Canley built cars from about 1977. These had the colour coded back panel and the tartan seats and the SD1 5 speed gearbox. This is all from memory so I apologise if any of this is incorrect.
My guess is that the car is a later Pageant Blue Canley built car with a satin black back panel added by a later owner. _________________ 87 E 825 Sterling
88 E 827 SLi
88 F USA Stlg 827S LHD
88 F Sterling
89 G Sterling
90 G Sterling
90 G Vitesse Manual
91 H Vitesse
91 J Sterling
92 J Red Coupe
92 K Red Coupe
92 K Gold Coupe
93 K Gold Coupe
93 L Gold Coupe |
| Back to top |
1997 Rover Coupe
Posted: Tue Feb 09, 2010 11:40 am Post subject: |
Well i am not sure if it is pageant blue or tahiti blue in the light from the pictures. The badge on the front is the "Speke" badge and the silver wheel trims came in from early 77. Mine has these - as well as the lovely red tartan trim and hand crafted at Speke in May 77, inbetween strikes.
The only sure way to tell where it was built would be to look at the chassis number, the Speke built cars started with ACG....
Here is quite a good link about the factory...
http://www.youtube.com/watch?v=IBokyZ0wOmc _________________ Regards
| Back to top |
Posted: Sat Feb 13, 2010 2:02 pm Post subject: |
OK i may be wrong but i still think its Tahiti blue. Pageant is much lighter and brighter and i also say in 77 they didn't use that colour on the TR7.
That should keep the debate running.
Tahiti is much darker and almost lifeless in comparison but that doesn't mean to say i don't like the colour. _________________ Glyn
| Back to top |
neo Regular Visitor
Posted: Sat Feb 13, 2010 8:37 pm Post subject: |
| i will try to get some better pics eg closer ones if the owners about will ask some questions the car has been sat there a while now. |
| Back to top |
