| View previous topic :: View next topic |
| Author |
Message |
Simon Hubbard Rover Addict
Joined: 01 Sep 2008 Posts: 1015 Location: Sutton Coldfield, West Midlands
1997 Rover Coupe
Posted: Wed Mar 10, 2010 9:44 am Post subject: Brakes Binding |
The other thing that came of the MOT on Michelle's car was that the rear near side brake was binding slightly, i guess it is not quite releasing fully.
The MOT chap said he thought they just needed cleaning out.
I have looked at the "sticky" on this section for changing pads and discs so think i will be ok but i am not sure what is meant by winding back the piston (?). Is this done so that the rust and grime can be removed?
If any other advice could be given it would be most appreciated.
Many thanks. _________________ Regards
1997 Rover 800 Vitesse Coupe
1996 Rover 800 Vitesse Saloon
1977 Triumph TR7 FHC
1969 Triumph Vitesse mk2 convertible |
| Back to top |
CHR15E Site Admin
Joined: 30 Aug 2008 Posts: 7756 Location: Notts. J28 M1
1990 Rover 827 Sterling
Posted: Wed Mar 10, 2010 9:54 am Post subject: |
You have to wind them back rather than force them on the rear that's all.
Like the other thread I have some loose outside so can get pics. Or let you have a look when you're here Saturday. _________________ Chris
91 827 Si Manual + matching trailer
90 827 Sterling Project
94 Espace 2.1 DT
94 Espace 2.1 DT Spares car |
| Back to top |
1997 Rover Coupe
Posted: Wed Mar 10, 2010 10:16 am Post subject: |
Thanks again Chris, i am not sure what you actually wind back. _________________ Regards
| Back to top |
Richard Moss Site Owner
Joined: 29 Aug 2008 Posts: 6827 Location: Wolverhampton
1990 Rover Sterling
Posted: Wed Mar 10, 2010 10:37 am Post subject: |
If you look into the caliper, at the face of the piston, you will see that it has 4 slots. These are used with the special tool (or a set of long nosed pliers or a metal bar) to wind the piston back into the caliper.
You rotate the piston clockwise (as you look at its face) and the screw mechanism in the handbrake adjuster then draws the piston back into the caliper. If you just force it back in then you will break it. After winding back in it should have freed off a lot of the grot but I also squirt a little WD40 under the piston seal before winding back to lubricate it a bit.
When you've finished winding the piston in, it will still rotate but not go back any further. make sure that you line it up with the slots pointing at north, south, east and west relative to the caliper so that the lug on the padslines up.
Don't forget to follow the correct adjustment procedure - reassmble, pump up with the foot brake and then you should find the handbrake is OK. _________________ Site owner (for my sins)
2000 Alfa Romeo 166 3L. 1990 XJ6 4L Sovereign and 1969 MGC GT.
| Back to top |
1997 Rover Coupe
Posted: Wed Mar 10, 2010 11:13 am Post subject: |
Thank you for the advice Richard _________________ Regards
| Back to top |
