| View previous topic :: View next topic |
| Author |
Message |
jago Regular Visitor
Joined: 30 Aug 2008 Posts: 439 Location: didcot, oxon, UK
1988 Rover 827 Si
Posted: Thu Mar 11, 2010 11:26 pm Post subject: 4 pot conversion |
hi all i changed my wheel bearing on tuesday and noted that my discs are needing changing, so....i'm bidding on some 4 pot princess calipers and i'll make a kit up for the 285mm 827 discs...if this works we could all have 4 pot brakes for not a lot _________________ currently: R827Si Auto (modified) - Black
Clifford cox
previously:
lots |
| Back to top |
CHR15E Site Admin
Joined: 30 Aug 2008 Posts: 7756 Location: Notts. J28 M1
1990 Rover 827 Sterling
Posted: Thu Mar 11, 2010 11:30 pm Post subject: |
Are new ones easily sourced? _________________ Chris
91 827 Si Manual + matching trailer
90 827 Sterling Project
94 Espace 2.1 DT
94 Espace 2.1 DT Spares car |
| Back to top |
Richard Moss Site Owner
Joined: 29 Aug 2008 Posts: 6827 Location: Wolverhampton
1990 Rover Sterling
Posted: Thu Mar 11, 2010 11:32 pm Post subject: |
I thought that Princess calipers were scarce and/or expensive these days. _________________ Site owner (for my sins)
2000 Alfa Romeo 166 3L. 1990 XJ6 4L Sovereign and 1969 MGC GT.
| Back to top |
1988 Rover 827 Si
Posted: Fri Mar 12, 2010 9:25 am Post subject: |
they are no to hard to get hold of, however at a later date if i want to upgrade them it's a std fitment _________________ currently: R827Si Auto (modified) - Black
Clifford cox
previously:
lots |
| Back to top |
Mark827 Regular Visitor
Posted: Mon Mar 15, 2010 12:53 am Post subject: |
Most people use the Princess calipers to put on MK2 Escorts.
I'll be really interested to see if this works because I've for ages been trying to source a cheap 2 or 4 pot caliper that fits the standard disc.
I managed to do that on my Merc by adding some washers to space out the caliper but it took a lot of groundwork first to get some to fit. _________________ Mark
'92 827 Coupe |
| Back to top |
1988 Rover 827 Si
Posted: Mon Mar 15, 2010 9:33 am Post subject: |
There are plenty of kits to modify them for vented discs, also if this does work i'm hoping i wont have a repeat of the disc cracking issues....
Clifford cox
previously:
lots |
| Back to top |
Posted: Mon Mar 15, 2010 11:48 am Post subject: |
I've had a lot cracked disc problems in the past on my 827's, even with new Brembo discs. I once had one crack so badly that you could feel it catching when braking.
I don't have such problems with my current car but then I don't tend to brake as hard now for that very reason. _________________ Mark
'92 827 Coupe |
| Back to top |
1990 Rover Sterling
Posted: Mon Mar 15, 2010 12:25 pm Post subject: |
Look where that cracked - right through one of the drilled holes. They may aid cooling but they will introduce weak points into the disc. _________________ Site owner (for my sins)
| Back to top |
1988 Rover 827 Si
Posted: Mon Mar 15, 2010 1:13 pm Post subject: |
if i remember rightly i only had the discs 2 months and only did about 600miles....
still these std discs i have now are fine but low on material (17.3mm) _________________ currently: R827Si Auto (modified) - Black
Clifford cox
previously:
lots |
| Back to top |
MikeMedford Site Admin
1997 Rover 800 Vitesse
Posted: Mon Mar 15, 2010 2:07 pm Post subject: |
Most drilled discs are prone to cracking, unless they are a monsterous size and cost a small fortune.
Better off with bigger and thicker grooved discs.
Disc basically acts like a heatsink, larger the size and thickness the more heat it absorbs/dissapates.
Cracking and warping is caused by heat build up, 4 pots wont remedy this.
If keeping the same size and thickness disc as standard the performance difference between 1pot, 2 pot and 4 pot won't be much at all as it still has the same surface area and clamping force (unless changing brake servo as well).
Wear on pads and discs would be a bit more even, that's about it. _________________ Med
| Back to top |
1988 Rover 827 Si
Posted: Mon Mar 15, 2010 2:34 pm Post subject: |
i totaly understand about that, what i'm after is brakes that will reduce the chance, so in the end yes thicker discs and maybe larger diameter as well, but for now 4 smaller pots and new groved discs will do. _________________ currently: R827Si Auto (modified) - Black
Clifford cox
previously:
lots |
| Back to top |
BRG Rover Addict
1998 Rover Vitesse
Posted: Tue Mar 16, 2010 1:30 am Post subject: |
I totally despair of my front brakes. Mainly the discs. I'm on my 3rd pair (in 3 years). They just warp.
I've put progressively better 'quality' discs on. Still bog standard OE or equiv., but dearer. Last pair, I think, were something like £35+ each. Not massive money, sure, but come on....
I got Mintex pads last time, same. I think I get about 3 months, tops, before my right leg's in danger of getting broke by the juddering.
If I've checked the hubs once I've checked them 10 times for 'true' and they are.
I've always thought the Vitesse had inadequate brakes. Is it just heat? Purely getting too hot and getting splashed cold? |
| Back to top |
1990 Rover Sterling
Posted: Tue Mar 16, 2010 2:18 am Post subject: |
I've never had 800 brakes warp. Maybe I've been lucky. _________________ Site owner (for my sins)
| Back to top |
Posted: Tue Mar 16, 2010 2:48 am Post subject: |
| Richard Moss wrote: | | I've never had 800 brakes warp. Maybe I've been lucky. |
or you drive more sensible
| BRG wrote: | I totally despair of my front brakes. Mainly the discs. I'm on my 3rd pair (in 3 years). They just warp.
Mate of mine who had car before me (guy who fitted the brembos) used to go through a couple sets of discs (262mm) a year before these!
All depends on your driving, he used todo alot of 120+ speeds and the standard brakes aren't designed for that abuse constantly
Hoping they will last me longer as I am changing them back to standard items this week
What discs are you using now?
I'm fitting EBC discs (262mm) with Mintex pads this week, managed to get them both for £56 delivered  _________________ Med
| Back to top |
Posted: Tue Mar 16, 2010 3:23 am Post subject: |
| MikeMedford wrote: | Hoping they will last me longer as I am changing them back to standard items this week
I'm fitting EBC discs (262mm) with Mintex pads this week, managed to get them both for £56 delivered |
Why you changing from the big brakes? _________________ Mark
'92 827 Coupe |
| Back to top |
